Power wire, where to buy
Ok guys, where and what brand of 1/0 you guys using and buying from? I'm looking for something ofc and that doesn't break the bank.
The best bang for the buck that Im buying atm is from CT Sounds for 0ga OFC Kit . For 1/0 usually GP Audio You get a few other items in the package like RCAs and couple other little items that most Amp kits do not.. May even be cheaper to buy the kit from CT Sounds than by the foot elsewhere? Like GP Audio or SkyHigh Audio. I buy the Big3 from GP Audio
I will use Copper lugs rather than the ones in the amp kits usually unless I solder them. these have worked great for me. Im sure there may be a better deal elsewhere? But these have worked great so far for me
Also I'm looking for bulk wire not kits lol. And should I run 2 runs of 1/0 from the front to the back or would 1 run of 2/0 fine?
I got this 2/0 on amazon. It's excellent wire, tinned OFC, marine rated.
Red
Black
2/0 to 1/0 reducers
I use them strictly for the runs from the front AGM to the lithium bank in the rear. To the distro blocks, I'm using 1/0 gauge KnuKonceptz wire. I run them under the car from front to bac then out the spare tire well. Her are pics from the last build (after it was totaled and I clipped the sires out) stuffs to spendy to give to the salvage yard!
New build is a 4500 watt setup.
What are the amplifiers or amplifier are you using? What Vehicle? What Alternator size, existing or an HO alternator and what battery/batteries, is the starting batt. under the hood or in the rear of the vehicle?
Amp will be a jp23 v1.5, HO alt is a 260, have a agm under hood and will have a agm in the back, car is a 2015 Subaru wrx. I will be adding a 4 channel later and I want the run to the back to be enough in case I upgrade later.
This is what I'm running
That's a damn good price. Is it fairly flexible? That is the one drawback on the tinned OFC marine grade stuff I got on Amazon last time, flexible-ish.
I didn't have any issues with it but it's not quite as flexible as say skyhigh 1/0 ofc.
I'm happy enough with it that I'll be ordering more for my delta build 😂
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
ikpthegame
ikpthegame
MN
audiobaun
maylar
    Jun 2, 2024
    Jun 1, 2024
