Eq settings
  • 4
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as possible. If you're trying to make your audio sound good to you, then play with it till you like it. Most people here prefer a bass heavy curve and would feel a little underwhelmed with a preferring flat sound. It's really personal preference unless you're competing.
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
699
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
You are going to need to beef up your sub stage in that vehicle to get that kind of bass response. A good pair of American Bass XFL 10s or 12s or...
998
CarAudio.com Regular
Charlotte
chillin
maylar
    Jun 2, 2024
    Jun 1, 2024
