DS18? Newbie alert
Make sure this'll fit... I stayed close to Sundowns recommended box specs.
If you'd like plans Pm me and we'll go from there.
Hey Shredder, I appreciate all the info, but it looks way outta my budge range, I may just keep this bookmarked and come back once I've saved enough
Ok... idk your budget but an 12ev3, in a diy Enclosure and a S1-850 amp  is a fairly inexpensive decent bass option IMO.
There are cheaper subs that would easily out preform what he was originally looking at in the right box of course. Idk 260 plus wiring kit and some MDF seems well within his 500$ budget. I'll take a stab in the dark and say building a box is the issue. No idea what it cost to have a box built but even if all ya have is a circular saw and a jig saw it can be done... Really not too difficult to build box if that's the issue. Especially if someone else has done the design work.
So I've totally disregarded the DS16s after a little research, but I am totally brand new to all this, so pardon my ignorance 😂 - but you guys are recommending just the single 12" sundown with the S1-850? I could get a box built I'm sure, should I go sealed, vented, or bandpass? Should I go for a system with individual parts picked? Do prebuilt systems just not preform as well or are they overpriced?
EDIT - just saw all the above suggestions - Ya'll are the ****, I'm going to make a list on amazon and link it to double check (might buy em elsewhere) just to pull it all together and get a buddy to build me a box and wire it.. Thank you all
There's a fella up this way running those DS18 subs (their big 4" coil ones) and they're pretty solid for what they are.  I think the issue is any of those "all in one" kits are generally poor performers.   If at all possible buying things separate and buying/building a proper box would be far superior.
114
10K
I'm hoping 🤣 I still gotta decide on drivers up front but I might just the cdt components I got now and add a unity mid 🤔
42
7K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
887
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
Ethan Carlson
Ethan Carlson
denim
