Basic question about calculating RMS and total wattage of my set up
Hags222
canada
This question may be quite straight forward, but I cannot find an answer anywhere. I am new to this forum but I found the formula to ballpark estimate my total amperage. I do not understand one part. When you calculate this, do you add up the total RMS of the amplifier AND the subwoofers it will be powering, or does the RMS of the amplifier translate into the subwoofers and therefore I just use the RMS of the amplifier? I got an 8AWG power wire and ground wire for my soundstage SS500.1 and a soundstage dual 10” boxed subwoofer with an RMS of 500W and peak 1000w. I am now kind of doubting if my power wire be suitable for a small car, can anybody help?
Your amplifier is what is consuming amperage. 8 gauge OFC wire will be fine for 500 watts rms. A good 8 gauge OFC wire is rated for 60 amp load in a 20’ run.
Great thank you very much. Also, do you know if the fuse i should be placing near the batter would be fine if I use a 40 amp fuse? or should I use a 60 amp. There are x2 30 amp fuses located directly on the amp, but if I am correct these do not protect the wire?
Add the amperage of the fuse ratings on the amps. If your mono amp uses 2 30amp fuses and your voice amp uses 2 20amp fuses, that will be- 30+30+20+20=100. So an 100amp fuse and correct awg cable.
Wrong again. Stop giving advice.
How is my answer wrong? He is looking for total amperage to protect the cable run. If your amp uses 60 amps, you are not going to put a 40 amp fuse by the battery. You will deprive that unit of 20 amps. So if he had two amplifiers that use 60 amperes each, you have to fuse that cable with an 120 amp fuse. And of course a thicker cable that can take at least 150 amperes.
I think you might have misread it. I only have one mono amplifier, and the 8AWG power wire i am using is RATED for 60 amps, this much will not be consumed though...
No, those were just examples, not your particular setup. But you have to rate your supply fuse the same as your amp's fuse rating. If not, you could end up damaging the amplifier. When enough current is not supplied, the amp will heat up when you drive it hard or for an extended period. Have you ever seen used amps with melted power supply terminals? That happens because the wire is not tightened and the amplifier is pulling more amperage than that connection can supply. Another result are burnt mosfets or popping supply fuses. Worst case scenario would be melted supply cable causing a car fire. Even though you will not drive your amp that hard, it is always better to err on the side of safety.
It wasn't. That method works fine. Although not all amps have fuses.
That's not really how it works. Fuses aren't like light switches. A 40A fuse will suffice for a ~60A amplifier because the actual current draw of an amp with ~60A max would be nowhere near 60A the majority of the time, and on short term 50-60A peaks the 40A fuse wouldn't cause any problems. Fuses are just short pieces of thin wire. They take time to heat up, melt, and blow.
If you look at fuse specs, specifically time/current plots - ratings are what the fuse will pass basically forever. A 40A fuse would pass 50A for a long time, 60A at least a few minutes, even 80 for a second or so.
It could be argued that the smaller fuse has a bit more resistance and would create extra voltage drop -- yes, but only measurable, no where near audible.
Without the wiring diagram I cannot be certain of the color associated with the head unit remote on or even if there is one on the HU. I assume...
47
5K
I can't speak to carplay but I'm using a Joying unit for android auto. It's a single din slot with a screen that attaches. The single din units...
https://www.amazon.com/dp/B01EXOTD56/?tag=caraudiocom-20 Cant go wrong with these for the price and drop ins on HU power alone. They do much...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
318
Hags222
Hags222
canada
devin171moto
