Any info?
flex1483
Has anyone used the atomic subs recently? look at an ELE 15....anyone know if it could be a good daily sub? Can get one for a pretty good price but cant fine much info about them. Was also looking at the FI SSD V4.... anyone with any knowledge on these would be great....would go in the back of a dodge magnum running 1500-2000rms.
Hand made in the US with top quality coils. They used to be more known years ago but the foreign made overnight internet brands have taken over.
Get one and be different and blow away all of these inefficient cheap chinese subs that need 2-3kw to get moving.
I used to design for an Atomic team member. I was really impressed with their woofers. They seem top notch to me, and unique.
i appreciate it, i'm trying to decide between 1 15 or 2 12s but trying to stay around 3-3.5cu max, dont want to take the whole trunk
Post your vehicle space up and I'll tell you what I'd do. height width and depth
its a 2006 magnum, i'm currently on deployment, but i believe the max area is 39w x 30D x 19H from floor to window. the specs for the subs im looking at 15" ELE ported– 3.25ft3 2(4” ports x 15 ¾” long) (36Hz) F3=65Hz 1000w
4.0ft3 2(4” ports x 11” long) (36Hz) F3=66Hz 1500w (SB)
12" apocalypse ported– 1.5ft3 4” port x 19 ½” long (36Hz) F3=42Hz 800w
2.0ft3 4” port x 12” long (36Hz) F3=39Hz 600w
2.0ft3 2(3” ports x 15” long) (36Hz) F3=38Hz 900w (SB)
maybe even 2 15" apocalypse
12" Apocalypse
  • SPL SUBWOOFER FOR COMPETITION
  • 1500.WATT - 5000.WATT
  • Cast Aluminum Basket
  • Double stacked magnet
  • Long excursion 2-1/2 inch high temp voice coil
15" ELE
  • RMS 1500-10.000.watt
  • Extrem SPL subwoofer for expert competition
  • High excursion with triple layer foam surround
  • Double stack oversize magnet
  • 3' Heavy gauge high temp voice coil
  • Flat wire use for extreme heat of voice coil
  • Over 2-1/2 inch extreme long excursion motor structure
12” Apocalypse 15” ELE
Revc (ohms) 1 2
F0 (Hz) 30.32 30.77
Sd (sqM .055 .089
BL ( T/M) 12.02 19.51
SPLo (dB 91.76 90.13
Xmax (mm) 19 15
Dvc (mm) 65 75
Qms (m.q. 4.9 12.59
Qes (e.q. .289 .365
Qts ( totQ .273 .354
Vas (liter 54 83.86
Cms (uM-N 125 74.6
Mms (gram 212 358.88
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
796
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
I found the paper from when i was looking into compatible impedance's close to Bose HU... Cleaning out basement, lol found this and realize how...
14
flex1483
flex1483
Florida
flex1483
