Volume Sensitivity
  • 2
kazs
Michigan
I have a kenwood excelon touch screen similar to the ddx6906s but i think it’s a bit older, for some reason when it gets to higher volumes the volts from the amp (measured w multimeter) will jump by 4-6 volts per volume level and wherever i set my gain it only plays within even 6 volts of max at just one volume under max, so everything more than 2-3 volume down gets barely half volume from the sub. i have equalizer flat and all sound effects off. (if anyone knows about the sound effects and which are safe to use that would be great cause they definitely help the other music)
Welcome to the world of logarithmic scale.
The issue here is that sound intensity revolves around the foundation that 1dB is about the audible threshold for humans hearing a difference, but 3dB requires doubling power to achieve, so your average source unit is rolling somewhere around 1 to 1.5dB per "click" on the volume knob. If yours jumps from 4-6V I'd figure you're about 1.3dB per click. Generally speaking if the numbers on your source unit go from 1-30 it'll be 1.5dB per click and a 1-50 will be right around 1dB per click. 35 and 40 total clicks in your volume sweep put you somewhere around 1.2 to 1.3.
Long story short, this is how it's supposed to work and this is why you can go from playing music just fine to hard clipping and/or breaking **** really quick with just 1 more click of the volume knob once you've hit limits.
The big problem with all of this, in gain setting, is that if you throw in a music track that's mixed a little lower you may still need 2-4 more clicks on the volume knob to really get the output you want and get your source unit up to 4V or whatever it is you're trying to match to your amp. At the end of the day, you need to plan around the wider range of music to which you listen, gain accordingly, and just be mindful with that volume knob when the louder songs come up through your playlist.
Those Kenwood units should also have sub gain functions in the "sound settings" menu and also gain functions for each source which may help you dial this all together to match to your liking.
Wow thanks so much, this is exactly what i needed!
If your last problem was the same as this one, you know exactly where to start. Does it change based on vehicle speed or engine speed? Does the...
148
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
315
what ^ said. amp gain setting info, test tones are at the very bottom...
628
Factory. 2021 Chevy Silverado custom trailboss
904
kazs
kazs
Michigan
kazs
