(1) Sundown ZV6 2-OHM 12" 2500W RMS - Suggestions on Automotive Electrical Help and Amplifier Recommendation Needed
Will I break a windshield?
  • Yes
    Votes: 0 0.0%
  • Maybe
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Ryann627
I currently own a 2000 Chevrolet Cavalier that I am currently building a subwoofer install in.
My complete and current installs:
New Kenwood KDC-BT378U radio with built-in speaker amp, All new door and deck speakers. (COMPLETE)
Big 3 Kit, Mechman 270 AMP Alternator, (1) Sundown ZV6 12" 2-OHM 2500W Subwoofer (wired to 1 OHM), One run of 1/0 gauge wire complete with fuse and capacitor), Fiberglass Subwoofer Box
Just wondering if all the above installs with be able to comfortably power a 3000 watt amplifier to run the subwoofer properly? I know Sundown Subwoofers are underrated, just not sure if I want to over-power by more than 500W, seems safer to me like that, unless I'm wrong? Never dealt with this much power before, max was 600 watts before this build.
Any other install recommendations? Bigger battery because it is stock? Better springs for the added weight in the rear? Box will be fiberglass but the subwoofer alone weighs 95 pounds.
Thanks in advance guys.
Get rid of the capacitor.
I would be adding a rear battery for sure.
Just because you have a 3k amp doesn't mean the subwoofer will be seeing 3k watts. Always good to have headroom as well.
Yes one run of OFC 1/0 will be plenty.
It's only one 12. You aren't going to even be close to breaking any windshields or needing any suspension mods.
They're basically the Chuck Norris of car audio. It's definitely a strange discussion, but I reckon if you were limited to a 500W amp I could...
605
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
Ryann627
Ryann627
Pennsylvania
