RDS audio 8 1 cube 35 HZ
making sure the lexan doesn’t flex or rattle. The mint isn’t bouncing so that’s good. The grill doesn’t rattle either and the sub doesn’t hit it, but it’s close.
You're grills with the bars are so damn clean dude! When I finally get around to building the box for my buddies accord, I have to ask how you go about doing them and what materials you use. Seriously dude, so f*cking clean!
Thanks man. I should’ve taken pictures of the back side. I basically just make the wood frame then router in slots from the back side for the rods to sit in. Fill the slots with some clear silicone, push in the rod down and staple it.
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
217
SlugButter
CarAudio.com VIP
SlugButter
arizona
Bobbytwonames
