Mounting amp 2014 Honda Accord rear seats
  • 6
ygbodybuilder10
Ok so I have two amps and Im keeping it as simple as possible nothing extra. All I want to know is the size/dimension wood I need to be able to drill to the back of the seats. and add the amps. The only cutting I plan to do is the cutting i tell home Depot to do at the store. I
Both. Brands are skar
The first amp is
RP-75.4AB | 500 Watt 4-Channel Car Amplifier
and the second amp is
RP-1200.1D | 1,200 Watt Monoblock Car Amplifier
The first amp is
Depends on how you want to lay them out and how you trunk is laid out. That's part of what makes car audio unique
A tape measure comes in pretty handy when measuring the area that you plan to utilize and give for the amplifiers:rolleyes:
i put my amp on my box. turned out great. and i used L brackets to secure the box to my car...
41845
41846
It should be very straightforward. 2 rectangular objects, place them side by side and measure how big they are together. Then you know how big the wood needs to be. Measure the area you plan to mount the wood to and confirm it will fit.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
552
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
ygbodybuilder10
ygbodybuilder10
United States
