Image dynamics id 8
People are usually pretty shocked when they see I'm only running 4 - 8's and that I've broke my overhead console and rear view mirror. Are you running the Id 8's?
Nice! Nah, I’m running a pair of Ct sounds strato 8’s. Seems my box needs some work so I plan to build a new one. I’m wondering if my 4” port is enough for them. I plan to build a new box and Incorporate am armrest. These subs are impressive. Want to make sure I get the most out of them before moving in to something else.
I was trying to go areoport with the two 8's in my 62' Bug and couldn't get a good fit. I just went with a slot port and hit 142.9 @ 33 hz. A box around 1.7 cubes net tuned around 33 hz. should be good for you.
Sounds good. I was actually shooting for 1.5@33hz. 1.7 is good for me though. Easier for me to use aero port. Just need to know if a 6” aero would be too much or just stick with a 4”
The problem with the 4" for me was that I think it needed to be around 13" long. Is that right?
When you ran the 4" port with these subs before were you getting any port noise?
If you're talking to me we never even built the box with the areoport because it required a 90° bend and we didn't have the room under the magnet. I just said, "screw it just go subs up and port up!"
Absolutely. I have an IDMAX 12 in a 1.65 cubic sealed box on 900 watts and it sounds great. You won’t be disappointed. Pull the trigger.
23
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
Ridinhi
Ridinhi
Winston-Salem, NC
