FEATURED Downfiring box for my truck
Ridinhi
Simple pic(s) of a new build for my single cab truck. Not going to take as many pics of the box but once I incorporate cup holders,etc, I’ll post more. Box will be 1.7@33hz
Much appreciation to @SlugButter for the help!
Subs will be down firing with port firing foward. Ct Sounds Strato 8’s.
Actual ”enclosure “ is done. Test fit and it’s perfect. Now I will spend the next day or so and come up with a design to make it an actual console. Gotta lift it about 2.5-3” and add armrest, cup holders.
Man.. That turned out pretty nice. Have you powered it up yet? Curious as to how it performs for you?
Not yet, I may mount subs in box, lift it a few inches to find a sweet spot just to see how it sounds. Got to get my amps mounted behind passenger seat as well. Had a few hours of decent weather before it got too cold again. Imma see how much I can accomplish tomorrow.
Not having a heated garage or shop *****. I usually don’t need heat in southern AZ, but December and January are the only 2 months where it’s a problem. 27 degrees out here in the desert this morning. I’m doing everything under heat lamps right now. My shop looks more like a baby chicken hatchery than a work space.
High today is 44. Won’t be soo bad if the wind take the day off. I may get some cardboard and Draw up a template to attach to the box and go from there.
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
163
520
822
650
Ridinhi
Ridinhi
Winston-Salem, NC
Ridinhi
    May 19, 2024
    May 19, 2024
