Ground zero 7104 XSPL 7x10'' box design issues
Sake_Pdk
Dear all,
I recently bought these speakers. Put them in some cheap, sealed, boxes you can buy on ebay etc. Im running them on a 250watt amplifier. The high tones sound perfect. however they simply sound horrible in the mids, presumably because of the poor box design and size. Anyone who can help me what to do with the box design? Or anyone who has more specs for these speakers in particular, cant find much info about them.... I do not want to mount them free air in the trunk as i use my cars music with the trunk opened a lot.
kind regards.
Try playing them out of the box. If they still sound bad, then the box is not the issue. If the sound improves, then add some pillow stuffing to the box (just a little).
already have some pillow stuffing in there, they dont necesarily sound that bad. just cant play that loud before they start to sound bad. Sounds like they want more air to work with. I just dont know how much they need :p
Are you trying to run those full-range? If you are not using a high pass filter you will run into mechanical limits of those well before 200W.
I would like to design a box for them that is allround from 80 hz and above. Im simply not able to find the required specs to do such calculations.
In that case, I would suggest using the parameters of an 8" sub in the same power range. For sealed and 125 Hertz you should be fine just being in the ball park.
I do not believe a different box will fix this and I generally distrust those """4 way""" coaxials. You could add some pieces of wood or even bricks or rocks or anything to shrink the effective box volume and see if that helps anything, I don't think a larger box will do anything.
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
nice! yeah i don't know if that would be enough or not for the bigger setups... people here say it's enough for easily 10kw but i'll research...
14
Thanks a lot for the diagrams, really helpful! I also found this youtube video showing how to wire to 2 ohms: Also, is this wiring kit suitable...
31
6K
The GTP 609c cost 142 USD as well as the infinity PR6510cs. as per reviews on the net, the 609c is among the best for SQ/quality music.
14
I'd take the Morel Maximo 6 over anything on your list.. 169.99 or so from Crutchfield.
23
7K
Sake_Pdk
Sake_Pdk
The Netherlands
hispls
