Enclosed amp rack connection ideas???
  • 2
GoT_2B_BuMpN
Hey all...So, I am currently working on building my amp rack for my Tahoe. It is enclosed type with fans etc. With plexiglass cover. I am working on planning my wiring. What I would like is for the wires ( 1/0 Power & Ground, Speakers & RCAs) to be able to connect somehow to outside of enclosure. So that I could connect/disconnect & remove if necessary. Instead of just drilling holes in the side and running through that way. Any ideas on this? Products that I could use? Where to buy?
High current DC connectors. same connections used for battery chargers. Get at least 2. They plug into themselves. They act as a female or male at the same time,
Ok. How about speaker and RCAs?
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
Getting a good voltage reading does not mean good power transfer. You could read 13.8v out of a 24 AWG wire. Recheck your amplifier's ground and...
260
474
GoT_2B_BuMpN
GoT_2B_BuMpN
No Conway, New Hampshire
GoT_2B_BuMpN
