My 2014 Honda CRV EXL audio build.
  • 2
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post pics of the build in about a week once I get the new amp installed.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
JohnPD
JohnPD
Ravenna, Ohio
JohnPD
    May 19, 2024
    May 19, 2024
