Rv headunit change
norman6
So I wanted to upgrade my old RV head unit. It’s an ancient Linear series. I bought just a cheap regular android radio off Amazon. Following the diagrams on old and new, I have power and functional headunit, but no sound at speakers. Amp keeps cutting off power. I also tried to bypass using the amp, and connect only non amplified speakers etc…. No luck any way I’m trying.
Is there a special way to make this linear series setup work with a regular car stereo headunit?
what ^ said. amp gain setting info, test tones are at the very bottom...
556
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
norman6
norman6
hamiltom
