Bends in a round port
You’ll get port noise bending round ports, negating the advantage of using round ports. Round ports are more efficient and have less internal surface area than a slot port, until you put a bend in it. Now you have a turbulence point. The only way to avoid this is to get 16 SQ. Inches of port area per sq. foot of box space, which now means multiple bends and a lot of box space taken up by port. I love round ports and use them all the time, but they need to be straight with no bends and they need to be flared. My 2 cents.
Just needed a port about 25" long for a 6" port, but I could drop down to a 4" port then it's only 10.5" long
Is it a single 12? 4 inch ports work fine for 12s. I had this box in my SUV for a while with a few different subs ranging from 500 watts to 1500 watts and they all did fine with the 4 inch flared port.
What’s up y’all, new to this place… today actually… Idk, i guess if I’m gunna ask for help wit this mess, now is prob the time…. First things...
Once you get the tools and basics down it's not too bad. The turn table is a must imo.
https://audioassemble.com/round-vs-oval-speakers/#:~:text=If%20you%20opt%20for%20a,it%20is%20small%20in%20size. This is what I found with a...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
797
ikpthegame
ikpthegame
MN
