RCA cable questions
6r33n3y3z
38
FL
Hello everyone. I was really into car audio 30 years ago. It has been a long time since I have installed or wired a complete system. I want to make sure I purchase high quality RCA cables. I was considering the Stinger 6000 series. I will need 6 channels total. Do any of you have any experience with the 6000 series or and of the newer Stinger cables? https://stingerelectronics.com/coll...hannel-triple-shielded-interconnect-12ft-3-7m
I like to have a little extra as I swapp amps usually. Its nice to have the extra footage if your amp kicks the bucket and you need that extra for a new amp/amplifiers or make changes. 18" is a nice # for me on the extra needed
I agree with that.
Stinger and Monster are rip offs for RCAs. If you have to use a car audio brand, then use KnuKonceptz Klarity cables.
When did they go to ****?
I agree with that.
They've always been overpriced. It's just marketing hype. Who needs balanced twisted pair for car audio unless they're running balance input/outputs which would be pretty rare.
I had a pair of gold plated Monster Cables in the early 90’s. They definitely sounded better than the cheaper ones. Zero interference IMO.
It's really hard, almost impossible to induct noise into RCAs. All you need is a simple set of shielded RCAs. Some home audio guys once did a test using coat hangers for the RCAs - nobody could hear the difference.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
883
Yep, the subs don't move at all when both RCA cables are plugged in. I updated the firmware this morning. Unfortunately it didn't fix my issue...
33
7K
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
924
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
769
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
862
6r33n3y3z
6r33n3y3z
FL
Jimi77
