Basic active subwoofer installation information.
Merton69
26
Bristol
New here, so hello to All.
At the young age of 53 I have just bought myself my first car (bl*ody divorce!!).
I have recently bought an InPhase Active Subwoofer that will hook up to my Civic '09's factory Head Unit. Got to keep things cheap as court fees are ££££'s.
Anyway, I have been told that I need an IOC and saw an excellent one on Amazon (SCOSCHE LOC2SL Line-Out Converter with Bass Control) that includes a wire that will connect to the SW's power input that will switch it off and on the the car is switched off and on so it doesn't drain the battery.
Does this mean I don't have to run a power cable from the battery as the instructions suggest please?
Note: The instructions are on the understanding it is an aftermarket car stereo and not a factory head unit.
Thanks Doxquzme for your reply.
I am UK based and can't get the Kicker at a cheap price.
I am not after loud super clear audio, just a more bassy sound to enhance the factory audio set up.
Hence, keeping it cheap.
As for your setup, the circled input in that reply is where the LOC (built into the amp) is located. You don’t need a LOC other than that. All you do is take the leads off of a pair of existing speakers (or tap into them from the HU, then run them to the powered sub. The LOC you mentioned is garbage, need it, don’t need it, and don’t get this one. The only thing that the Kicker LOC affords you is the ability to (as is the case with the built in LOC on the sub) tap into speaker wire anywhere there is on (L&R speakers, Frt. or Back), behind the HU or wherever and turn the powered sub on and off without having to run a turn on/off remote power from the HU. If you have a set of rear speakers you can tap into, using the Kicker LOC allows you to tap into those speakers, run them to the amplified sub without the need to take the HU out for anything else. Both configurations (w or w/o) an aftermarket LOC still require you to run power from under the hood (reasonably speaking) back to the powered sub. Here it is in the UK, $35.00, still on the inexpensive side of things.
Amazon product ASIN B07VKFSLKN
In a nut shell, this aftermarket LOC if you don’t want to pull the HU to use the HU remote turn-on lead, no LOC if you ar able to pull the HU and run the lead yourself.
As for your setup, the circled input in that reply is where the LOC (built into the amp) is located. You don’t need a LOC other than that. All you do is take the leads off of a pair of existing speakers (or tap into them from the HU, then run them to the powered sub. The Sosche LOC is garbage so if you go that eroute, don;t buy that one. The thing that the Kicker LOC affords you is the ability to (as is the case with the built in LOC on the sub) tap into speaker wire anywhere there is on (L&R speakers, Frt. or Back), behind the HU or wherever and turn the powered sub on and off without having to run a turn on/off remote power from the HU. If you have a set of rear speakers you can tap into, using the Kicker LOC allows you to tap into those speakers, run them to the amplified sub without the need to take the HU out for anything else. Both configurations (w or w/o) an aftermarket LOC still require you to run power from under the hood (reasonably speaking) back to the powered sub. Here it is in the UK, $35.00, still on the inexpensive side of things.
https://www.amazon.co.uk/Kicker-46KISLOC2-Stereo-Line-Output-Converter/dp/B07VKFSLKN/ref=sr_1_1?crid=3BA10LZSO9JL6&keywords=kicker+LOC&qid=1692757606&sprefix=kicker+loc,aps,391&sr=8-1
Hello All again.
Hope this post finds you all well.
This little project had to go on hold (as explained) but hopefully soon will all go ahead.
Just one question please:-
The speaker cables coming out of the SW will travel along the side of the car and into the HU.
But I don't know what cables I will have to splice to join the speaker cables to???
The fascia is apparently a very long winded job just to get to the HU, so I don't want to go in blind.
Does anyone have an idea which cables are the speaker cables coming out of the HU, that I splice into to connect the SW speaker cable please?
This is the only stumbling block (and time set aside) stopping me from going ahead.
Thank you.
Remind me of the configuration again. HU speakers output to the Kicker LOC? Which sub and what amplifier for the sub?
Thanks for replying Doxquzme.
It's a InPhase Active Subwoofer and rather than clogging up the forum with more gumph and images, page 2 has the configuration and some images.
Hope this helps. Thank you.
So, assuming that you aren't using an LOC and are using the hi-level (speaker) inputs, use the speaker leads off of any of the R/L speakers (front or rears) in the car. It is important to use both R/L leads from a pair of R/L speakers so the sub amp can sum the signals from both sides of the music source.
In a nutshell, if you have access to the rear or front speakers, then use a lead from one left and one right, off the speakers themselves if that easier, to the subwoofers level inputs.
If you look at my wiring diagram, I still need to get to the back of the H/U to connect the REM connecting cable.
Where on the back of the H/U does this REM based cable connect please?
Just like my previous comment about the speaker cables..."The fascia is apparently a very long winded job just to get to the HU, so I don't want to go in blind."
Plus my garage is not right by my house but away from it, which causes issues.
many thanks.
The blue/whit wire from the HU should be the remote turn on if you don't have an LOC.
As for the speaker leads, you can just run a pair of leads off the back of any L/R speakers from either the front or the rear speakers, it doesn't matter if it is the front or rear, just make sure you use L&R from either the front or the rear to the high level inputs on the powered subwoofer.
Once again, thank you for replying Doxquzme.
I now understand the speaker cable situation but have become so confused with the REM cable???
I was told the Blue/white cable came out of the HU and into the REM port on the SW (hence the diagram drawn as it was for initial confirmation).
You are now telling me differently, so please can you explain?
Plus, it still doesn't answer my initial question about what cable/port does the blue/white cable connect to, with the back of the HU?
Sorry for all the questions but I am a total newbie to all this and my budget refrains me form getting it doen professionally.
Do hope you can help.
Please provide the make/model of the head unit you are going to use so I can look at the wiring diagram. Your diagram above is correct as only as the HU has a REM wire coming out of it.
Thanks Doxquzme.
I have tried to see what model the sound system is but can't find anything.
It is a stock system that came with the Honda Civic SE 1.8, 2009 I bought a year ago.
I can't speak to carplay but I'm using a Joying unit for android auto. It's a single din slot with a screen that attaches. The single din units...
https://www.amazon.com/dp/B01EXOTD56/?tag=caraudiocom-20 Cant go wrong with these for the price and drop ins on HU power alone. They do much...
769
Merton69
Merton69
Bristol
