New JVC Head Unit with Android Auto and Car Play.
  • 2
huberoy123
I was driving the other day and my old JVC stereo started to make crackling noise, and intermittent pops. After some investigating, I discovered that one of my amps has gone bad. This was after I had torn my dash apart and pulled some of the wiring. Since the dash was apart, I decided to upgrade my stereo. My wife's SUV has android play in it, and I had been considering upgrading. This particular situation gave me the reason to do so now.
I lost my DVD with the new unit but gained USB mirroring and Android Play. I also retained Sirius Radio and USB function for my hard drive, which I use more than any other source. I hope this turns out to be a good decision.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Ok thanks I removed the wires from the back of the unit
Google do it translate what ever i do
407
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
huberoy123
huberoy123
Delaware
