Keep blowing one speaker
cluxford
Chasing an ongoing issue. On my rear 6x9s about every 6 months one channel blows the speaker. I've now replaced the speaker 4 times. It works fine for 6 months then one day (like today) it just starts going all static and basically crap and I have to disconnect it and replace it. Just one output. The other rear speaker has not missed a beat and it's over 2 years old now. Is it the amp? My wiring? any ideas ??
What amp, what speakers, in what, wired how?
Pioneer AVH-Z7250BT 7" Single DIN
Rockford Fosgate P1683 Punch 6"x8" – in the front
Rockford Fosgate R169X3 Prime 6"x9" – in the rear
Rockford Fosgate PBR400X4D Punch 400 Watt Full-Range 4-Channel Amplifier
It also has a Kicker 46CXA400.1 – 400 Watts RMS Monoblock Subwoofer Amplifier and Kicker 48CWRT104 10 Inch CompRT 4 Ohm Subwoofer
The issue occurred before I installed the subwoofer and continues
Wiring. Sub is wired off it’s own output to the amp then to sub.
Speakers are wired using RCA from headunit to amp, then wired using LF, RF, LR, RR outputs using proper gauge speaker wire
You can pull that amplifier and take to an Audio shop and see if they will test it. Most shops charge very little and some will not even charge you at all.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
217
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
The best thing you can do is make a solid plan. This way you won't be spending money twice and having to keep going back in add or replace parts.
27
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
535
cluxford
cluxford
Austrlia
