Weak bass
  • 6
Jerryrich12
I have 2 kicker L7 15s. 4000 watt American bass amp. JBL 4 channel amp for the mids and highs. Everything was working fine until I loss bass. Bass still plays but it's very weak. I hook them up to another battery and subs starts hitting again. Not to mention I have 2 optima yellow top batteries with a 370 mechman alternator. Help. Thanks
check all your power wires, ground wires and fuse blocks. 1 bad connection somewhere or even just a slightly loose fuse could cause this. You could also have a bad battery, but I’d expect the car wouldn’t start if that was the case. Still a possibility to check.
Deff check all your connections to make sure they are secure. Alternator,batteries,fuses,grounds,amp sub wiring inside the enclosure and at the amplifier.
I have to try another serpentine belt too. Mechman says to try a 1/2 shorter than stock because the alternator pully is 1.75 smaller than stock
Absolutely. When I ordered mine from Apex, they recommended the next size down for the same reason, the pulley is slightly smaller. Makes a lot of difference from what they told me.
Connections are good it was hitting pretty good for months then all of a sudden weak bass.
How old are your batteries? A belt that slips on the alternators pully deff makes the resolution contact an issue to maintain the voltage output that the alternator is designed to work at. You can take a DMM, or Multimeter and place it at the alternator output while the vehicle is running and play your system to see how much the voltage range is when on and off, and at the last battery as well. Two points of testing the Voltage
Batteries are practically brand new. I'll try this over the weekend. Still have a 2yr warranty on both Batteries.
Any hairpin alternator like that will always require a minimum of at least a 1/2" shorter belt up to as much as a 1" shorter belt due to the pulley they put on them. I tried a 1/2" shorter on mine and it worked but when I went to a 3/4" shorter belt it made a slight difference but for the better. Nice thing is you take the length of the OEM belt, how many groves from Dayco then from there can order the belt you need. My 1/2" shorter one even though have a ford is the right one for a small dodge car iirc. The 3/4" inch shorter belt is off some foreign car and the 1" iirc works on a chevy, ford or jeep,lol. As long as it has the right grooves even though it is that 1/2" shorter or as much as 1" shorter it is a belt it will work.
Maybe check your alternator output? Also rip out all that audio 0 gauge crap and buy high end welding wire…..much better capacity for amperage to flow……also make sure your yellow tops are charging properly…..do this buy disconnecting everything and run a volt meter on it….
Done all that with a multimeter and voltage was reading the proper voltage. Alternator reading 14.4 battery charging. Battery resting stage at resting voltage 12.4. Sent my amplifier off for repair. There was some defects found
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
790
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
You may even look into an indash PreAmp EQ that will allow for more control at your finger tips along with an increase of voltage signal...
They're rated for 250wrms, so you were overpowering them, especially the poor 10s. XBL subs sound really clean at their limits due to the flat BL...
355
Jerryrich12
Jerryrich12
Mississippi
Jerryrich12
