Trunk floor
I covered my the rear space in my vue with 3/4 mdf...everything is mounted down to it in some fashion or another
I actually like working with MDF. It's easy to cut and shape. Plus it takes glue very well.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too, prevents vibration chattering later on down the line.
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
im trying to figure out how to get a set of lift struts to go onto my sentra trunk lid. i tried the springs from amazon, but they are not strong...
