2015 Nissan Altima speakers
nissssssan2015
CT
Hi,
I'm looking to replace all the speakers in my car for better quality ones. I'm trying to come up with a parts list of things to order so I can take it to a shop and they can install it for me. I just want to make sure I have all the things I need.
I came across this website (https://allspeakersize.com/nissan/altima) that has a list of all the speakers in the car.
1705822162313-png.105335
I know it would be 4x of the 6.5s for the four dours but how many tweeters, center channel speakers, and 6x9 speakers do I need? I have a part list of some of the things I currently want to buy, what else would I need to complete this list? I want to make sure the speakers have the proper hardware to function properly as well.
Current list (Amazon only please):
Front doors https://www.amazon.com/dp/B0777Q7WVB/?tag=caraudiocom-20
Back doors option 1? https://www.amazon.com/dp/B0777TKXVF/?tag=caraudiocom-20
Back doors option 2? https://www.amazon.com/dp/B0777SSHQ8/?tag=caraudiocom-20
Bundle? https://www.amazon.com/dp/B09RHFLVZH/?tag=caraudiocom-20
Tweeters https://www.amazon.com/dp/B009MS7DS8/?tag=caraudiocom-20
6x9 https://www.amazon.com/dp/B07GZ651HM/?tag=caraudiocom-20
Adapter https://www.amazon.com/gp/product/B007ZQVKYM/?tag=caraudiocom-20
What's the best route to go? Thanks!!
I would look at some Polk Audio DB series. You using the original HU/Stereo? What stereo/HU is in the car? Whats the Budget?
The original/stock one. I was considering adding one of these but I'm not too set on it.
Budget is around $800, don't want any subs just want to replace the stock units
Would replacing the stock stereo/radio help with anything for my project?
First task is to find out if you have an OEM amplifier. If no, then an aftermarket radio and a adapter harness will make the project way better.
If you have an OEM amplifier, you will need an adapter harness that has integrated female RCA jacks, or integrate a passive LOC yourself. OR, you can bypass the OEM amplifier and run all new wires to every speaker location (hardest option IMO).
I believe part D in this diagram is what you're referring to? What are you able to deduce from this photo? Does it have an OEM amplifier or what I'd need within it's stock parts?
It tells me that you do have an OEM amplifier. The upgraded Bose system adds rear door speakers and a dash speaker. You can definitely get by with just upgrading the speakers. The information you need from the OEM speakers is the size and resistance (Ohms). If the OEM radio is to your liking, no need to replace it.
Are you able to take out one of the frint door speakers. The rear shelf mouted speaker magnet should be visible from the trunk. It should have the Ohms value printed on it.
I believe my car spec doesn't have the bose package. Would this mean the OEM aplifier would differ and be less powerful with the standard sound system?
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
Hello there! I'm gonna own a Civic LX pretty soon ( the one with the touchscreen ), and I'm wondering about a few things ... In my current setup...
nissssssan2015
nissssssan2015
CT
