Logitech Z623 Subwoofer to car
  • 5
K Tuu
Hello!
I have HK Logic7 sound system in my MB W211 T, and added Z623 Sub into trunk for more bass.
Aux cable connected to factory sub cable:
It plays very good, even the rear view mirror vibrates now :D
Bypassed this:
With this:
I have two questions:
1) How i could make the sub play only bass, can hear lyrics also at the moment. Factory sub plays only bass, no higher notes. Logitech sub has Amp inside, maybe it affects it?
2) If i turn music volume down from head unit, Z623 volume stays the same, factory sub's volume goes down (HK sub box is empty inside. Nothing between below sub and Aux cable). Dual voice coil subwoofer:
Should i add Hi-Low converter between original cable and sub's RCA connectors?:
If there are voices coming from the sub, then it is getting a full range signal.
I think the crossover for this computer sub is in the speaker that you bypassed. You need a line out converter (LOC) that has a dedicated sub out like the Audiocontrol LC2i.
You kind of dumping money into a losing battle, better to bypass your cars factory sub and get one of the these. From eBay EU
He's trying to use a PC subwoofer setup in a car. Those don't take much power to begin with and are built for PC setups not cars.
Yeah, saw that, trying to steer him away, waste of money to add a LOC that has a sub out ot one that has some sort of manual crossover.
Trying to use home of computer equipment in a car is usually a losing battle. Even if you get all of the electronics to work, the temperature extremes of being in a car can kill speakers designed for home use in a very short period of time.
I will not recommend any particular car subwoofer to you, as I don’t know what is available in your country.
You can add a passive x-over between the HK harness and Logic sub. Just know that an inline passive will also affect the HK sub's frequency curve. As for volume, just turn down the Logic volume to more less match the HK.
You may even add the passive x-over after the Logic amplifier. That os probably the best route.
559
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
K Tuu
K Tuu
Estonia
    May 19, 2024
    May 19, 2024
