Installing dash cam. ACC Fuse Location?
stevef22
Hi, Im installing Ventrue N4 Pro dashcam in my 94 F150. Its calling for a ACC fuse. Not sure where or what this is. Cant find on diagram. Thank you
ACC fuse is the accessory fuse. You can pretty much just use any fuse that turns on and off with the ignition key. The radio fuse is usually my go to.
Many thanks guys. I tied it into the radio fuse. 1st timer here in a long time. (Used to do this in highschool)
Should work good there. I always try to use Accessory when available for power and and ground at the rear frame work under the dash, and use On/Of with Radio, or cig. Lighter if it only operates by ignition to power up.
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
141
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
stevef22
stevef22
San antonio
stevef22
    May 19, 2024
    May 19, 2024
