Power wire, where to buy
I didn't have any issues with it but it's not quite as flexible as say skyhigh 1/0 ofc.
I'm happy enough with it that I'll be ordering more for my delta build 😂
I am going to try and get some samples, see how it compares to the Anchor marine cable I purchased prior. Hell of a price! If it is even AS flexible, $30 less for a 25 ft run, $60 less on dual 2/0 runs. AND, if you order it a little extra, would have enough for a BIG 3 upgrade!
Looks like its some tope grade wiring. id like a bit stiffer wiring for one my trucks for sure. maybe for my 2500 HD I plan on doing by next summer. Deff try some out. Thanks for the recommendation man. ill check it out
Ill deff check some out as well in couple months.
The 2/0 eb flex is roughly the size of 1/0 ofc sold for car audio
The anchor product measures similar. Much of the 1/0 for cars is loosely packed to give it extra flexibility. Here is the Anchor tinned 2/0 versus KnuKonceptz 1/0 flex -in jacket and when stuffed into a ferrule. The blue is Knu, the black is Anchor marine and the ferrules are L-Knu, R-Anchor.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
ikpthegame
ikpthegame
MN
    May 19, 2024
    May 19, 2024
