Backup camera
  • 2
I'm not sure if I have the red wire that's connected to the video input connected to the right wire on the harness can someone tell me where to put the red wire from the video input on the camera to on the harness like witch one is going to be the trigger wire to power on the camera on this harness I circled the 2 only options o believe
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
How positive are you that the reverse camera power supply was spliced in with a reverse light wire? If you used one of those blue wire splicers...
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
You will definitely want to read what the Reverse wire does, and what those two blue wires by the rear camera video input do. That should tell you...
Charlotte
    May 19, 2024
    May 19, 2024
