Speaker terminals
So my new gp box is awaiting shipment and I have everything for the box. The only thing I forgot was speaker terminals but I saw they make you lose power so how would you wire your amp to the subs? Would you just run it straight to the amp? Would use speaker terminals? Or do you have other ways of doing it?
It wouldn't be a noticeable drop. Gp and smd made good terminals
I just drill holes the same size as the wire and caulk the inside around the wire.
I have used these in the past.
Supreme Binding Post Banana Jack Power Speaker Terminal​
Parts Express
Part #260-314
You can use any that you like, really. The drain is barely measurable. No more, no less, than fused power line interruptions, the length of the terminal is just too short to really make a difference. I do solder the wire behind right up close to the huts on the rear of the standard terminals though.
You can also just use a heavy spade on the rear too, they will all work.
Parts Express Gold Binding Post Banana Jack 5-Way Speaker Terminal​
Parts Express
Part #260-302
I use these so I can change it up from 4 ohms to 1 ohm if I wanted to. Use or don't use the breakers depending on the load I want.
Parts Express Bi-Amp Speaker Terminal Cup Gold Binding Post Banana Jack​
Parts Express
Part #260-281
We're talking about maybe an inch of right around 8 gauge transfer material, not an issue.
THese are pretty nice as well.
Dayton Audio BPA-38SN HD Binding Post Banana Jack Pair Satin Nickel​
Dayton Audio
Part #091-1247
I have done as others have done too, just run them through the box and onto the amp, only issue is, if you want to move it around, you have to disconnect everything from the amp, kind of a pain,
You can use any that you like, really. The drain is barley measurable. No more, no less, than fused power line interruptions, the length of the terminal is just too short to really make a difference. I do solder the wire behind right up close to the huts on the rear of the standard terminals though.
Your links just take me to the home page
Dang I said no to gp terminals when I got the box
If i'm not mistaken, GP offers Steve Meade Designs type terminals and I'm not a fan. Stainless steel is a lousy conductor, brass is better, copper is best (well, silver is technically, but $$$)
Stainless steel is a poor conductor of electricity, with an electrical resistance of 7.496×10−7Ω⋅m, which is more than 40 times worse than copper. This is because stainless steel is an alloy, typically composed of iron, chromium, nickel, and other elements, which can interfere with the flow of electricity.
The last one you recommend are nickel should I look for sliver ones or copper ones
https://www.cdtaudio.com/cdtnew22/index.htm I'd look here instead of entry level from those brands. I've been running cdt HD series components...
278
381
343
Charlotte
    May 18, 2024
    May 18, 2024
