SOLD 12" Pioneer TS-W5000SPL
Whattha
Oklahoma
MODEL TS-W5000SPL
SIZE 12 inch
SUGGESTED RETAIL PRICE $900
SYSTEM Sealed, Dual 4 Ohm Voice Coils
INPUT (MAX) 5000 Watts
(NOMINAL) 1500 Watts
CONE Interlaced Carbon Fiber Reinforced IMPP
SURROUND Fiber Woven Radial Rubber
Wide Roll, Overhung Surround Design (Invisible Screw Holes)
MAGNET Triple Stacked Magnets (Ferrite)
MAGNET WEIGHT 320 Oz
VOICE COIL BOBBIN Glass-Imide, 3 inch
VOICE COIL Copper Round Wire
Ceramic Coated
DAMPER 9 inch Conex Double Damper
Vented, Die-Cast Aluminum Support
POLE YOKE Extended, Vented
AeroDynamic Magnetic Gap (ADMG)
FRAME MATERIAL Die-Cast Aluminum
TERMINAL 8 Gauge Wire Terminal
IMPEDANCE 2 or 8 Ohm
LOWEST RESONANCE 32 Hz
SENSITIVITY 89 dB
FREQUENCY RESPONSE 18-2,000 Hz
DIMENSIONS 12-7/8" x 12"
MOUNTING DEPTH 10-1/2"
WEIGHT 69 lbs.
Qts .32
Fs 32.2 Hz
Vas 1.09 (ft3)
ENCLOSURE SIZE 1.5 cu. Ft.
Sub is perfect. Only has bout 3 hours play time on it. 8/10 cosmetic 10/10 mechanically
300 plus shipping or any sweet trade.
I have this sub listed as well as 2 Kicker L7 12's and a US Amps MD3D, id be willing to combine everything I got on a sweet trade. Or package everything up for a good combo price. If you need any more pics or anything pm me with your cell number and I can sms you some pics.
Well Im not going any lower than 275 shipped. Ill look at the **** thing before I give it to someone. It slams and it needs a very small enclosure for the size of the sub. Id trade it for a high end 4 channel amp or some Shok 0 gauge. Dont be shy guys
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
466
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
890
Whattha
Whattha
Oklahoma
Whattha
maylar
    Jun 2, 2024
    Jun 1, 2024
