2 12" kicker comps and a 15" kicker comp?
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif You should probably add 2 15's so that you hit the lower lows.
I already have a 12" ported box with the two 12s and I have a factory sub on the side and I wanted to get rid of the factory sub and put the 15 in the factory sub box
You can put the 15 in. But don t forget, you should really add a 10 as well to even it out so you can pick up high notes as well.
Lol.... Op, although it its hilarious watching you get trolled, google mismatched subwoofer sizes, or something similar. That will answer your question.
Google says not to mismatch sub sizes or shapes lol. Comps can sound good but with 1500w on tap why not upgrade to some cvx or even better a couple sa12s or incriminator lethal injections, or ssa gcons or skar vvx or obsidian 12s
823
zSTePPyy
zSTePPyy
Nebraska
Why So Cereal?
maylar
    Jun 2, 2024
    Jun 1, 2024
