(2) Kicker ZX750.1's
cdimic25
(2) Kicker Kz750.1s
•mono subwoofer amplifier
•375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
•variable low-pass filter (50-200 Hz at 24 dB per octave)
•variable bass boost (0-18 dB at 40 Hz)
•subsonic filter (12 dB at 25 Hz)
•Class D design
•CEA-2006 compliant
•speaker-level inputs
•preamp outputs
•fuse rating: 40A x 2
•4-gauge power and ground leads with 80-amp fuse recommended
•14-3/4"W x 2-3/8"H x 9-11/16"D
#1: Appearance- 10/10 Performance-10/10
#2: Appearance- 9/10 Performance-10/10 (small knick on bottom fin)
#1: $180+ shipping
#2: $175+ shipping
USPS comes as shown
#2
I wish I could come off these HDMI cables so I could buy these.. Unless you happen to need some very high quality HDMI cords 26ft, retail at $330
821
cdimic25
cdimic25
cdimic25
maylar
    Jun 2, 2024
    Jun 1, 2024
