2013 silverado 3500hd
Got bored today and built a little book shelf box for my old set of Memphis viv mids. Learned real quick that they don't do below 80hz well especially on 250w to the pair. They never really did well in my doors either which is why they were removed anyway, they used to be run at 125 each in my doors since they are 2ohm mids
Decided to update things a bit
Install is currently
Alpine ilx f509
DD Dsi-3
D4s mm1004
Stereo integrity tm65mkiv
Stereo integrity m3carbons
D4s mm1004
DD ceramic a series tweeters
Adire audio koda 8 front sub
D4s mm1000
Adire audio koda 10s
80ah of yinlong charging to 15.5v
Behind the seat looks a mess but it's about as clean as I could get it without custom rcas. Next time when I swap the dsp to a helix I'll do custom rcas to clean things up.
Still need a box for the koda 10s. They are for sale unused right now since I want to go stereo integrity sql10s instead and would hate to build 2 boxes when inevitably upgrade later. When I upgrade tk the sql10s I'll be dropping in a soundigital 3000 or a mmats lsx4000
I'll drop in a new 250amp alt then as well
In my front doors I have a pair of American Bass VFL 65MB in each. havent heard them in almost 4 years, inputs on my amps are gone. LOL
Planning a build on my SRT Jeep first though.
I have a alpine PDR-f50 here in Springfield la id let go for 100bucks works fine just took it out yesterday if that would help you get back up and running
it would...after i swap head units out. it's what caused the issue. So instead of buying an optical input dsp, I bought another head unit, same model, LMAO. Thats when I realized I still have the optical output to go into a dsp (like a mosconi)... i'll look into it, imma do some research on that alpine
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Anyone? Anyone? Looking at the audio control d 6.1200
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
Ponchatoula, La
    May 31, 2024
    May 24, 2024
