2014 Accord Sport SQ Build keep_hope_alive
Prior to doing the Hertz HL70 mids, I experimented with some LaVoce mids (same basket, different cones). This pod also featured 3D printed grills that screw on. These mids were ok, but they had a noticeable amount of coloration when compared to the Hertz.
Been a few years. This car is still going strong. However, it has a new driver! My 16 yr old daughter is now using this as her daily at 220,000 miles. Still runs, rides, and sounds great. I swapped the speakers for some stuff I had laying around (Type R woofers, LaVoce mids, Hertz HT25 tweets) but the rest is the same. In spring, I'll start a new build on my new ride:
Welcome Back.!! Very Nice New Ride!! Im always intrigued and learning from your builds .This one should be another great one to follow as well. Looking forward to it
My man! Good to see you back man, can't wait to see the new system/build, hit me up if you are interested in the stuff I've kept stashed away.
P. S. I blame you for how complicated my jetta became.
Matt
Thanks, guys. The new ride will be getting disassembled soon, now that it's warmer (yes, I drove it all winter).
I'll do my typical build log for the Camaro. Lots of measurements and data, with an initial budget upgrade with measurements and data to show how it behaves with a modest effort before putting what I like in.
My daughter managed to give the Accord a facelift - so it comes back from the shop in a few weeks with a new front end! Can't kill it, it still rocks. But she will be helping install different amps/speakers since the Hertz/JL will transfer to the Camaro.
So, where are we at in August of 2023? I gutted all equipment. The wiring remains, but is being re-worked.
Once all of the hardware was removed, I showed my daughter how we made panels back in the day.
I also showed her how to design a speaker pod and we’ll give these a shot.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
743
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
keep_hope_alive
audiobaun
    May 19, 2024
    May 19, 2024
