$300-$500 setup
  • 4
Prestondrew40
Car audio enthusiast
70
Mobile
Looking to upgrade my subwoofer setup, I would prefer for it to stay under $300 for just subs and box or $500 for subs, amp, box. 2 12’s or 15’s would be best with at least 1200rms total. Drop any advice, setups, or questions
May consider building the box, but limited on time with work and school.
SomeOne else’s time is going to be money too with an enclosure. Maybe someone on the board can give you a box design to build yourself based on your vehicle and the woofer(s) you pick. Used can be your friend check OfferUp and letgo.
What’s your existing substage comprised of? Maybe you can make partial changes versus all new everything.
If we’re throwing it equipment recommendations I really liked these when I had them and they’re somewhere in between popwar’s picks from a price point. 600 rms but I gave my 10’s around 800 each and they could have taken more.
You indicated you were upgrading your sub stage, but your electrical scenario will dictate what amp you can get. You probably know this but electrical upgrade will pull you out of that budget. With amps There’s more than a couple of 1800-3000 watt budget amps in the 180-250 range that dyno their actual ratings. Unfortunately a lot of the decent Chinese 1200-1500’s hover at about 200$
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
716
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
991
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
Prestondrew40
Prestondrew40
Mobile
BCotrell
maylar
    Jun 2, 2024
    Jun 1, 2024
