adding a lifepo4
Joshua Sim
utah
i am adding a 64 ah 600 v 7200 w lifepo4 battery bank to my system i have a 110 ah agm up from i have a 250amp isolator 160amp alternator i have the big four will be running 2/0 wire what else will i need to install to help my lithium bank i was thinking about leaving the 105 ah agm that i have in the back as well as add the lithium bank but i think that could be over kill i am running rockfordfasgate 13”t2 with the rockford t2500amp 2 kicker l7 10” on the rockford t1000 4 skar npx65 6.5 on the rockford r2500x4 2 skar super tweeters ona punch 300 2 chanel also have 2 jy hybred super capacitors 2000 faired each they run to the t 2500 only would add pics if i could figuer out how
that’s my system first is isolator then my bank my amp rack and subs
Wish I had advice to give, but I don't. I'm about to a similar point myself though.
Where are the two Kickers hiding? I am a fan of Solobarics.
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system and your car. You might want to have, at least, a 350 amp alternator. You're batteries don't mean much if your charging system can't keep them charged. That goes the same with the system's performance. Keeping a steady 14.4v will give better performance.
970
Thanks. That makes sense. It sounds pretty good as is.
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
I have a jeep grand cherokee that is controlled by pcm but I have a external voltage regulator . I just switched to cmax and when I went to turn...
Joshua Sim
Joshua Sim
utah
Old_Slapper
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
