**Advice needed** Am I going to damage my sub with this amp??
  • 6
I do not know why those users would warn about a little more power. You can set the Gain low to put out the power you need. The formula is A/C Volts = Square Root of (Watts x Ohms). In your case you want to give the sub 750 watts, the sub is 3 Ohms. 750x3 = 2,250. Square Root of 2,250 = 47.43.
Connect your multimeter to the amp's sub output (no sub), set multi to AC Volts, turn gain up until you get 47 Volts.
Thank you!
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
To find out what fits, head over to Crutchfield.com. For actual purchase you may want to try CDT.com. They seem to have an everlasting sale. Good...
I blew the pico fuse on multiple Pioneer decks and they changed to thin wiring on their harnesses so went to Kenwood. I never used Network Mode...
KcContractor
CarAudio.com Recruit
KcContractor
Olathe, KS
audiobaun
    May 18, 2024
    May 18, 2024
