DrReamery
So after finally amassing the parts to put together MR2 system 2.0, I'm at the tuning part. I've run into a snag though:
I picked up a used (great shape on inspection) Alpine MRD-M501 on ebay, and during tuning I noticed the temperature steadily rise. The digital readout said it was about 67 degrees when I began, and a couple hours later it was just shy of 130 degrees! Too hot to keep your hand on. In the time of those couple hours I ran the system at moderate volume for ten minutes maybe three times, and the other amp (MRV-F540) was barely warm to the touch. I seriously doubt the sub-amp should reach those temps.
The other thing I noticed was the subs were "flexing" when I had a track paused. PAUSED! No sound was coming out of the subs (or the rest of the system) but they were moving back and fourth at what looked like most of their excursion with a slight stutter. Is this bad for my speakers?
The JL 8w3v2 D4 subs I THINK were fine at first, but now there's a definite rattle / vibration / baffle / waffley sound to one of the subs but not the other. I took that sub out of the box and made sure it was wired right (it's a dual-voice-coil). Then I inspected it. Nothing was wrong with the spider, cone, or wiring; it looks brand new. I put it back in the box making sure it was sealed and then I double checked my series wiring (which is brand new) through the car. I did the 9v battery check and the speaker moved forward, just like it's supposed to. Finally, I swapped the wiring for the boxes and the vibration stayed with the same sub.
I used the DMM tutorial on JL's website to set the gains, and on the sub amp it's set to 0 input (-24 - 0 range) and the gain is at +6 (0, +6, and +9 are the possibilities). I'm running at 4 Ohms. The amp puts out a rated 275 watts feeding the subs that want 125 each.
Bottom line: Does it sound like I have a busted A55 amp? Is it possible it damaged my sub? What the hell is up with a moving, flexing sub when the music is paused?!? Is 130 degrees normal?
Thank you so much for taking the time to read this, even if you can't help.
Derek-
Derek-
