Amp problem
  • 2
yea but later on im going to disconnect every wire, and try it on my friends wires if it does the same i think i might open it up and check or just buy a new one.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
781
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
728
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
157
sq_joshua
sq_joshua
los angeles
sq_joshua
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
