Amp question
the amp I have now is a 2 channel so the car is wired for that should I stick with a 2 channel or rewire it for a 4 channel? does it matter class d or a?
681
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
floridaguy727
floridaguy727
arkansas
floridaguy727
maylar
    Jun 2, 2024
    Jun 1, 2024
