AMPLIFIER AND ALTERNATOR HELP
  • 2
Alejandro17
So I'm intrested in two Soundstream T5.122 Tarantula T5 Series 2,000 Watt 12″ Subwoofers each is rated at 1,000 RMS. I used the amplifier slection tool on https://www.sonicelectronix.com/Matching-Subwoofers-Amps/2-63-94454?filter_f_op_123=232 . I know I want a class D mono amplifier and I want each speaker to have 1,000 or more RMS but no more than 1,500. I'm planning on adding this to my 2004 Ford F150 XLT Extended Cab. The vehicle has a OEM 110A alternator and a regular 12V battery. I need some help if whether or not I have an adequate amount of power to run the whole system.
Depends on your use of the volume knob.  :)
But seriously, it does.  Adding a volt meter to the dash would allow you to monitor voltage and you will get to figure out how much of an issue it is.  Usually, it is typical to install first then assess the need.  Certainly, the stock alt would struggle if you achieved the actual power output (clamped) that you desire.
But if you end up being happy when the actual output of the amp(s) is around 500W then maybe you're fine.  We won't know what volume level will appease you.
Certainly start looking at possible alternator upgrades and make sure the battery you have is healthy.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
404
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
879
870
Alejandro17
Alejandro17
keep_hope_alive
maylar
    Jun 2, 2024
    Jun 1, 2024
