Are my upgrade equipment compatilbe?
Ben Mulcahy
Hello, I am relatively new to the audio upgrading. I am wondering if the Phoenix Gold ZDAPVW1 is compatible with the Pioneer TS-A250D4 10'' subwoofer. Or will I require a separate sub amp for the sub? I have attached the specs of both the amp and sub. Thanks for any help or advice.
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you need to be.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
577
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
777
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
Ben Mulcahy
Ben Mulcahy
Ireland
audiobaun
    May 19, 2024
    May 19, 2024
