Big 3 + to alt fuse?
Gh0st
Texas
I know there are some threads on this already but I’m looking for a specific answer regarding my setup, I’m doing a big 3 upgrade with 4 awg wire, should I fuse the battery to alternator wire, and what size/type considering 4 awg, also I’m not replacing factory wiring just adding to it, any help is appreciated.
No need to Fuse the Alternator wire to Battery. Ive never had any issues.. EVER. Fuse the Supply wiring from Battery to amplifier. no need to remove existing wiring from alternator or grounds. Just Add the Big3 to those locations necessary.(Alternator to battery, Ground battery to engine Block, and Battery Ground to frame/Shock blot or Strut bolt
All surfaces need to be cleaned off of any Painted surfaces and Use Ring terminals highly recommended so the connections are solid.
The reason for the fuse is to protect the battery if you have a short. Most cases its a short and sweet trip to the battery. If you have one in the trunk.... fuse it.
Thanks, I’ve just heard people say you need to and then many say you don’t, want to do everything the best I can to protect the car, electrical, and the amplifier. And yea I’ve cleaned the paint off to bare metal, using copper ring lugs, sprayed rust preventative clear coat over the connections, just have the power wire left, my car requires removing TB and intake manifold to access alternator power contact, so I’ll be finishing this weekend. I appreciate the info.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
Gh0st
Gh0st
Texas
Gh0st
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
