Box design for 1 Re audio sxx 10" help
  • 2
I'm trying to build a box for my RE audio sxx 10. I just want to make a simple L port enclosure. It needs to be around 1.25 cu ft and tuned to about 34 hz. I designed one on re box calculator than read this calculator is not accurate. I need help designing this! I tried some other design things but I just can't figure it out so I'm hoping someone else can help me out here. I dont need you to completely design it for me if you dont want i just need help. Please help! Thanks.
(Ps. Dimensions can be fairly big. Only thing is height needs to be around 14 in)
661
992
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
839
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
Tshaffe
Tshaffe
Tshaffe
