Center Console Box 18' Silverado
  • 2
Mitchc1113
Here are some pics of my new enclosure. I currently have an SSA Icon 12" in a rear middle seat enclosure in my 2018 Silverado Double Cab... I got a new Resilient Sounds Platinum 12" & had to change the enclosure.
So I decided on a new center console, but it had to be a beast as the Platinum weighs in @ 70lbs!! I also needed it to still work like a console, cup holders, compartment, USB ports, etc... I also wanted it to look OEM when you see it, but when you really look at it know it's something custom. I think everything was achieved. Box is built to specs straight from Resilient Sounds, I have cup holders, compartment, USB ports, even a wireless charger custom fit to my Galaxy Note! Theres also spots for my DSP remote, a trim ring for my Halo power switches and a volt meter!
But enough talk...
Looks like good airspace, port area and... wow... fabrication.
Tour de force...
Great job!
Shredder, thanks & got my specs straight from the owner of Resilient Sounds who got them from his head builder so I hope they're good, lol!
2.25ft^3 before displacement tuned to 33hz... shes pretty big, but doesnt look ridiculously big for a console, which is what I wanted, gain back some space and keep a somewhat OEM look. But when u look closer be like that's not stock OEM!!
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
683
Well I ordered an oscope. Should be here today. And this beautiful beast showed up today. I’m gonna have to redo my battery and ground terminals...
36
6K
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
503
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
Mitchc1113
Mitchc1113
Pittsburgh, PA
Mitchc1113
Decebal
    Jun 10, 2024
