Charging lithium
  • 2
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I just use a power supply.
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
  • Locked
I think the guidelines want members to have a picture with your forum username and current date in the picture to avoid scammers. :)
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
maylar
    Jun 2, 2024
    Jun 1, 2024
