Chevy 99-07 ext cab box for 10s
matslp488
Looking at these 2 boxes for my subs… anyone here have any experiences with any of these boxes…. I really want to get regular size subs but if shallow mounts are my only option then shallow mounts it is…. Just want something with a tight punch that will be somewhat loud…one is a probox and the other is a skar audio box both around $150 specs also attached
Sundown SA10v2 has a mounting depth of 6" so they will work with the ProBox. They require a sealed 0.5 cubic foot per sub so box is a bit bigger but you can fill it in or play it as is.
Skar Audio SDR10 works in that same box as well with 600w RMS each.
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a single ported enclosure for a 10" that you can use a single ten that will work just fine made for that year model. If you use the sealed enclosure. Id recommend these subs without digging too deep in the pockets.
variant=39570195349659
Amazon product ASIN B01N5D2PD0
Amazon product ASIN B07S946DPY
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
675
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
matslp488
matslp488
McAllen TX
audiobaun
audiobaun
    May 19, 2024
    May 19, 2024
