E39 Sub/Amp Install
  • 2
gladiator_jai
Rolla, MO
Hey guys,
I did it. Thanks to 'bigaudiofanatic' from here and the umpteen people whose posts I have been reading for a couple of weeks. Thanks to Douglas Baker for his awesome blog and Bavarian Sound Works. Most importantly thanks to the quotes by local shops of $700+ for what I have done in $150, as that was my biggest motivation.
Now moving to the pics:
The ride: 02 BMW 540i with DSP.
The Stuff:
Subs - 2 x JBL GTi MKII 10"
Amp - Sundown SAE-1000D
Headunit - Stock
Wiring - Kicker 4GA kit I pulled from my honda.
Box - Sealed .75^3/Sub.
The trunk with stock subwoofer enclosure:
After I removed it:
Stock DSP Amp:
Box:
Drilled //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :
Amp Mounted:
Subs Wired - In parallel to 1.5 ohm(They're dual 6):
Both in:
The box got so heavy :cussing: //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif:
Tapped into the the wires from the harness that was disconnected from the stock subwoofers:
The LOC hooked up:
All finished and done. The subs look sexy //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif :
I'll be posting up some vids tomorrow. They sound wonderful. The gain is set to 1/4 currently and I have ample bass. Will run some test tones tomorrow and set the gains properly. The lows are so good. Thank you JBL //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. I've been coveting these subs for quite some time and they did not disappoint me 1 bit.
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
Sounds like you already have a plan. Hook it up and let us know how it worked. Good luck.
458
487
gladiator_jai
gladiator_jai
Rolla, MO
gladiator_jai
maylar
    Jun 2, 2024
    Jun 1, 2024
