Enclosure Design
  • 2
Navy_Doc
Maryland
I suppose this is probably a noob question, but when finding the square footage for an enclosure does the port need to be added with displacement? for example. the DC level 4 12s need 1.5^3 ft for the sub, it has a displacement of .18^3 ft. do I need to find the cubic feet for the port then add that to the overall size of the box?
Yes. For your example, you'd want to see 1.5^3 ft. internal volume AFTER subtracting the displacement of the sub, port and any bracing.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
797
Navy_Doc
Navy_Doc
Maryland
Navy_Doc
