Engine whine and ground loop fixes... take two
If they don't make a sticky out of it just subscribe to it so you'll be able to find it easily later //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I say replace this with the other one that is stickied...
Damn Pioneer whining got on my nerves, so I went ahead and did it.
Sun went down and didn't have time to install it back so I will tomorrow.
Will edit the results in tomorrow.
I was talking about the MD2D. If you ground the outer jacket of the RCA it will sometimes solve the MD2D noise problems. It didnt solve mine so I sent it to USamps to get fixed.
IT fixed it... //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
I still have a little due to walmart [non shielded] RCA's
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
JohnPD
