Evl
  • 6
Just depends on what you want to spend. I'm selling one of these, never installed, still in the box for $300, shipped - about 2400 watts at 1.14 ohms.
You will want to wire 3 of the subs 2 coils in series Each 8" in series so all three are at 8 ohms, then run that group with the fourth (it's 2 coils wired in parallel to 2 ohms) then all in parallel to the amp for a 1.14 ohm load.
it's that or all four in a series/parallel configuration for a 2 ohm load. All 4 in parallel will knock you down to around .5 ohms, not a lot of amps under $5-600 dollars that I can think of that will take a .5 ohm load.
What is your budget?
If you wire each dual 4 ohm VC subs VC's in series to 8 ohms then run all four in parallel to end up with a 2 ohm load to the amp, bunch of amps that will get close to 2400 watts at 2 ohms.
$260
$599 (2500 watts at 2 ohms)
$500 (offer) 2300 watts at 2 ohms
$550 3000 watts at 2 ohms
$350 2000 watts at 2 ohm
I don't buy this companies product, the corporation is part of the Russian Federation, that just me.
$350 for 2200 watts at 2 ohms
So as you can see, any number of options wait you.
There are several good amps
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
SAMUELA81
SAMUELA81
California
AnthonyO
Decebal
    Jun 10, 2024
